I have a bunch of lines with some animation and I want to offset each line to have time variations, but using retime node inside foreach does not work.
What would be the proper way to use foreach with the retime node?
Simple retime with foreach
399 3 1- mzigaib
- 951 posts
- 8599 posts
- mzigaib
- 951 posts
- 8599 posts
mzigaibYou can use Blast sop based in iteration metadata to keep the correct piece, but the key is to use non cached Fetch As Input
Thanks for the feedback!
It does work if I use with "fetch as input" but it wont loop per line time shift just affects everything the same.
Edited by tamte - 2024年2月22日 15:24:21
