Hi guys,
I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work!
How can I fix it?
Thanks for helping.
Why the background image is not visible in the refraction!
557 7 1- Masoud
- 407 posts
- Enivob
- 2537 posts
- evanrudefx
- 225 posts
Masoud
Hi guys,
How can I fix it?
Thanks for helping.
Is this karma xpu or karma cpu? the background plate lop doesn't work with karma xpu. It was supposed to work in houdini 20 but it does not. The background plate lop has a vex based material and vex based materials only work with karma CPU. There is supposed to be a materialX material in the background plate lop for xpu, but it isn't there. Sidefx logged this as a bug when I reported it a few months ago.
Edited by evanrudefx - 2024年4月16日 10:51:42
Thanks,
Evan
Evan
- Masoud
- 407 posts
- Masoud
- 407 posts
- evanrudefx
- 225 posts
- Masoud
- 407 posts
- evanrudefx
- 225 posts
MasoudYou should post the hip file so I can see what you are doing wrong. Even if that didn't fix it those changes needed to be made.
Hi @evanrudefx, no it doesn't fix the problem.
edit: I see the other issue. In your photo you dont have a primitive to use as a holdout. You need to place a grid or some type of geometry behind the sphere and assign it as the primitive to use in the background plate lop.
Edited by evanrudefx - 2024年4月18日 10:01:24
Thanks,
Evan
Evan
