SOLVED
I tried everything from suggestions as seen bellow but it seems that the Attribute Paint node doesn't work well in older Houdini Versions. I tried on 20.0.688 and works fine!
I'm a newbie but I've create an Attribute Paint and hit Enter in the viewport and the brush doesn't even appear.
I also get this error when I want to add a new attribute "AttributeError: 'module' object has no attribute 'updateattribute", but I would honestly just be happy to have the brush appear.
Let me know if there are any suggestions, thank you.
Attribute Paint not working - help
4243 14 3-
- Alexandra_Chiosa
- 23 posts
- Tanto
- 547 posts
- Alexandra_Chiosa
- 23 posts
- Tanto
- 547 posts
- Alexandra_Chiosa
- 23 posts
Tanto
Is it possible your Alembic is still packed? If so you won't have access to the geometry (the rest of the setup won't work correctly either). Try to use a a convert node after the object merge.
Before the screenshot I showed, I have a simple setup for my alembic (which I reference in Object Merge node) and I already have an unpack and convert node. Not sure what else would work in this case.
- Tanto
- 547 posts
- Alexandra_Chiosa
- 23 posts
- Tanto
- 547 posts
Your setup seems fine. I don't have the alembic file, but substituting it with a random one, I was able to paint without a problem.
In this thread [www.sidefx.com], somebody with a similar problem seemed to be able to fix it by using the numpad enter, you might want to try it. Otherwise, updating your driver to one supported by SideFX [www.sidefx.com] might also be a good idea.
- Alexandra_Chiosa
- 23 posts
Tanto
Amazing, thank you for having a look! I will check the links. Also may I ask what Houdini version did you use to check the file?
- Tanto
- 547 posts
- Alexandra_Chiosa
- 23 posts
- Alexandra_Chiosa
- 23 posts
- Anthony_Gregory
- 3 posts
Attribute paint not work on our Houdini also - gives 20.5. 278
Clicking the visualize button give error 'module' object has no attribute 'visualise'
Please can you help?
File "Parameter Scripted Action", line 1, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.278/houdini/python3.11libs\hou.py", line 57070, in __getattr__
return _hou.HDAViewerStateModule___getattr__(self, name)
AttributeError: 'module' object has no attribute 'visualize'
Ant
- wyhinton1
- 95 posts
Also getting this problem when using attribute paint, very painful.
Tried using the numpad enter key, tried using different geometry (a box, a complex object, etc), and no luck.
H20.5.550
Here's the setup:
H20.5.550
Traceback (most recent call last): File "Sop/attribpaint/attribname1", line 1, in <module> File "Sop/attribpaint, PythonModule", line 3, in updateattrib File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.550/houdini/python3.11libs\hou.py", line 57190, in __getattr__ return _hou.HDAViewerStateModule___getattr__(self, name) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ AttributeError: 'module' object has no attribute 'updateattribute'
Here's the setup:
Edited by wyhinton1 - 2025年4月23日 23:00:58
- stucooke
- 19 posts
