nested shaderX
   1415   2   1
I have a car model with many sub-meshes (e.g., lights, wheels). I want to assign a shader to each sub-mesh. My current solution is to create a "Material Library" node and add a MaterialX Shader Builder node for each sub-mesh.
Question: Is it possible to group all the car's MaterialX shaders into a subnet, like this:
Material Library -> Car_Shaders (Subnet) ->
Windows (MaterialX)
Lights (MaterialX)
This way, the Material Library node won’t be cluttered with many shaders specific to the car.
PS: Attached image/hip file do not work! Just showing what I want to do...
Edited by catchyid - 2025年1月20日 23:37:26
nested_shaders.hiplc (159.3 KB)
You can use your Material Library just for car materials and create another for other shaders
That way you dont have to dive 2 levels deep
CG Supervisor
Framestore, NY
tamte
Or if you want to have two levels deep, then you should be able to put down a subnet inside the LOP, and put the material builders inside it. Then point to them in the LOP's parameters to create USD materials.
