Boolean cut geometry not applying material on a surface
1216 2 0-
- ray_roamer
- 10 posts
- CYTE
- 805 posts
It applies materials—the cutting object's material to the newly created primitives.
The material is a string attribute on the primitives called shop_materialpath.
If you want to have your cutting primitives inherit the same path, use an
attribute transfer node before the bool and transfer the shop_materialpath
primitive attribute from your rose to your cutting mesh.
CYTE
CYTE
Edited by CYTE - 2025年2月20日 04:07:06
- ray_roamer
- 10 posts
