Hi!
It seems the Curvature VOP is not currently supported under Karma, it returns shading artifacts. I have already sent a RFE, but just wanted to check if any of you have any hint about this being implemented any time soon, just like Dirt Mask, Rounded Corners shader and the limited version of trace() were recently included.
Karma support for Curvature VOP
4862 8 2-
- jarenas
- 146 posts
- anon_user_09389530
- 205 posts
I guess h19 should have a much better support for stuff like that, I hope. ¯\_(ツ)_/¯
I contribute to the beauty of this world
https://houdininotes.ivanlarinin.com/ [houdininotes.ivanlarinin.com]
- jarenas
- 146 posts
- joshuazt
- 6 posts
- 9434 posts
joshuazt
If anyone is still wondering, it seems the curvature VOP is still broken in karma, H19
which build are you talking about?
from journals it seems that it should already work at least partially
Houdini 19.0.469
Add basic support for getderiv to Karma. This version does not have special logic to handle smooth derivatives on a non-subdivided mesh. As a direct result, the Curvature VOP can now be used in Karma.
Edited by tamte - 2021年12月30日 17:41:25
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- joshuazt
- 6 posts
- iamsaitam
- 8191 posts
iamsaitam
I cannot get the curvature node to work in Karma with MaterialX.
That's because it's not a materialX node. Only nodes that start with mtlx and a few others can be used in a materialX network. They cannot be mixed with VEX based nodes (nodes that generate code) such as the curvature vop.
Creating a karma materialx subnet before starting can help you use the correct nodes as it restricts the available nodes to just those allowed.
- owelter
