Tennis ball Fur
4008 6 0-
- Chetal
- 7 posts
- marm0s
To keep it simple you could try copy to points with a bunch of tiny lines, with jitter or noise. The entagma tutorial on path deform in 18.5 uses a similar technique for moss (starting around 6:30) https://youtu.be/-TsA7nmivfA?t=394 [youtu.be]
- Librarian
- 142 posts
- Chetal
- 7 posts
- Chetal
- 7 posts
- davesturch83
- Heileif
- 303 posts
davesturch83
How would you go about adding a logo to this ball and also be able to change the logo colour?
https://www.sidefx.com/docs/houdini/nodes/sop/guideskinattriblookup.html [www.sidefx.com]
Can be used to pick up uv from the geometry at the root of curves.
