File pattern - Specific files selection
   4746   9   2
i'd like to use File Pattern TOP to select specific files from a folder, there is no pattern though, no similarities in naming.
Something like a multi parm menu would be super useful. Is there a way to do this with another node or do i have to built it myself?
Maybe File pattern is not the only node that reads files from disk?
Pattern allows wild cards such as ? (match any character), * (match any string of characters), and (match any one of the characters inside the square brackets). For example, *.png matches any file that ends with .png. But I don't think it's going to be flexible.
You can first read all the files from the disc using the *.extension template, and then filter the desired files using Filter by Expression.
alexwheezy
how can i filter based on specific files? i'd like to have a controller where i select the specific files so filter would have to read the filepaths from the controller and keep only those, discard the rest workitems
i have made an attempt here but this has to be automated somehow. maybe python?
File Pattern.zip (210.7 KB)
Then we can consider 2 more options to solve this problem.
Use Filter by Attribute or Labs Filter by Value, which is actually written in Python Script.
https://www.sidefx.com/docs/houdini/nodes/top/labs--filter_by_value-1.1.html [www.sidefx.com]
alexwheezy
where are you creating the attribute though? can you share a file please?
The File Pattern node knows how to create attributes from a path such as directory, filename, extension.
https://www.sidefx.com/docs/houdini/nodes/top/filepattern.html [www.sidefx.com]
Problem with this method is that for the labs tool you have to use python to add values automatically to the filter as you are adding more files in the controller null.
Edited by papsphilip - 2024年3月23日 13:02:48
File Pattern.zip (182.4 KB)
Why not use the Labs Filter by Value node itself as a control node? It seems that so far there is no problem to replace it.
All I've changed here is a setting in the asset that allows you to select files on disk rather than populate a line, then you don't have to create a new layer of data indirection and avoid the hassle of writing code.
Edited by dtempcyer - 2024年3月24日 01:22:24
thanks @alexwheezy! Here is the asset for anyone interested.
filter_file_selection.1.0.hdalc (11.8 KB)
In case you wan to process a folder with many many imagine, you want to avoid using the filepatern node, i mean filter the item before and not after... Or did i miss something ?
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
