Hi there,
Anyone knows how can I convert the .odp format of the Master Class courses into a .pdf format?
Or any free application for open them in windows?
thanks
pd wow SESI you are doing a great job with H9 beta and the new tutorials.
Houdini Master Class Course Materials
7021 6 1- onesk8man
- 32 posts
- graham
- 1907 posts
- stevenong
- 1631 posts
I think all users will appreciate it if the slides can be printed out as PDF. I'm using OpenOffice 2.0-pre & I can't see the slides. I opened the outline & the CPU was running full throttle for a few mins before I can see the contents. I tried to print but failed.
I don't really want to download OpenOffice to be able to print the slides out. If SESI can do it & upload, that will be greatly appreciated!
Cheers!
steven
Cheers!
steven
- wolfwood
- 4262 posts
- mertyamak
- 50 posts
- arzo
- 99 posts
- circusmonkey
- 2624 posts
I just coupled what was in the slide show with the help on the node ! to try and fill in some of the blanks. The issue I had was open office didnt play the embeded videos , but you could tell where they were supposed to be , the large empty area was the big giveaway ….
On a side note in the examples. The SOP scalar field node and others keep giving warnings stating
“Primative defined in obj/hotspot is not a volume” none of the examples then seem to work ?
R
R
Gone fishing
