Font list scrolling
   596   1   1
Is there a way to scroll through the Font list, or other lists in Houdini ?
There's this huuuge list of fonts and it smells like the only way to check what font to use is to open the dropdown menu , manually scroll down , select next font rinse and repeat....
I tried all kinds of hotkeys like Arrow Up/Down etc. but all that got me were crashes.
Edited by toonafish - 2025年11月14日 07:52:16
Sadly no. Not right now. The font SOP is truly outdated, and has been for years.
However, this is trivial to create a subnetwork that has an additional integer parameter, that holds a hardcoded list of the font files, and have a font detail attribute somewhere which the Font SOP can refer to using: details(...,"font")
I tested it with the actual font files (full path on the filesystem), and it's working.
And you can tie the font detail to a given element of the font list with a integer parameter.
in a detail wrangle
s@font=s@fontList;
Finally, this subnet could be saved as a Digital Asset, and be integrated into your operators. I can't tell you much more than that, but that's a way to do it,
