how to use normals from attributes on an agent?
1617 4 3-
- burlin
- cwhite
- 803 posts
This is a limitation with Hydra currently - it doesn't perform skinning on the normals and instead flags them as needing to be recomputed after the deformation
A workaround is using the Bake Skinning LOP which does support deforming normals, with the downside of the skinning being baked instead of happening at render time
- Nkv3D
It's not look like a Hydra problem, because I made the same test with Unreal Engine. For instance I export skinned character from UE to usd, and back, and normals was rebuilded.
On the other side Bake Skinning LOP is not a good choice,
because it bake into transforms matrix and point positions, which interpolated linearly in usd, and you can get squash & stretch effect between animation keys, and bad motionblur as a result.
- edlgm
- 23 posts
cwhite
Was this ever resolved? We are also trying to avoid using the Bake Skinning LOP for some of our assets with a ton of points.
Enrique De la Garza
CG Supervisor @Frame48
- cwhite
- 803 posts
This was very recently fixed upstream in USD (https://github.com/PixarAnimationStudios/OpenUSD/pull/3841) so I'd expect that to be available in the next major Houdini release
Another alternative workaround is using the crowd procedural, which has some options for baking out the skinning for all agents (equivalent to the Bake Skinning LOP) - this is done just at render time and for the relevant time range
