Seems like metahuman nodes are not working on Linux at all?
Is there any way to have that to work or we are forced to use windows for any metahuman related work?
metahuman plugin on Linux
173 3 3-
- Mirko Jankovic
- 286 posts
- william_harley
- 122 posts
- Mirko Jankovic
- 286 posts
- edward
- 8107 posts
Hi Mirko, I've tracked this down to an issue with how the MetaHuman plugin was built on Linux. As released on FAB right now, it only works if your Houdini installation was installed at
I'll be contacting the Epic folks on this so hopefully the next release of the MetaHuman plugin for Houdini won't require this workaround anymore.
/opt/hfs21.0.440. A workaround for this is to add the correct dsolib directory to your LD_LIBRARY_PATH prior to starting Houdini, something like this in bash:export LD_LIBRARY_PATH="$HFS/dsolib${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}"
