New hotkey: Display Nearest Node
   7400   16   3
Not sure if anyone needs it but I wrote a shelf tool that sets the display/render flag to the nearest node to your cursor in the network editor. When you bind it to a hotkey, it boosts your productivity by 2% as you don't have to carefully focus on the display flag of nodes to set them Just hover around with your pen.
If there is a simpler way to get the current cursor position over the network editor, I would love to know. Here is the code:
import ctypes
MOUSEEVENTF_LEFTDOWN = 0x0002 # Left button down
MOUSEEVENTF_LEFTUP = 0x0004 # Left button up
MOUSEEVENTF_CLICK = MOUSEEVENTF_LEFTDOWN + MOUSEEVENTF_LEFTUP
selNodes = hou.selectedNodes ( )
networkEditor = hou.ui.paneTabOfType ( hou.paneTabType.NetworkEditor )
currentPath = networkEditor.pwd ( ).path ( )
context = networkEditor.pwd ( ).childTypeCategory ( )
ctypes.windll.user32.mouse_event ( MOUSEEVENTF_CLICK, 0, 0, 0, 0 )
pos = networkEditor.selectPosition ( None, -1, None, -1 )
nodes = hou.node ( currentPath ).children ( )
nearestNode = None
dist = 999999999.0
for node in nodes:
d = node.position ( ).distanceTo ( pos )
if d < dist:
nearestNode = node
dist = d
if nearestNode:
nearestNode.setDisplayFlag ( True )
nearestNode.setRenderFlag ( True )
nearestNode.setSelected ( True, clear_all_selected=True )
Enjoy
Interesting hack, thanks.
networkEditor.cursorPosition()
Enjoy
Thanks a lot, simplifies my code a lot Now I wonder why that is not documented?:
http://www.sidefx.com/docs/houdini14.0/hom/hou/NetworkEditor [sidefx.com]
pusat
… it boosts your productivity by 2%…
Err… thanks???
Edited by - 2015年4月28日 22:41:19
kewl. thanks
mantragora
pusat
Err… thanks???
It's up to 7% now
New changes:
Simplified position checking (thanks to pezetko)
More accurate distance calculation
For Object level nodes, it dives inside the nearest node
If a node is already selected either manually or with this tool and it's called again near the same node, it dives inside. So press the same hotkey twice if you want to dive inside Attrib VOPSOP, Volume VOPSOP, etc.
For VOP nodes, it selects the nearest node
networkEditor = kwargs
currentContext = context.name()
pos = networkEditor.cursorPosition ( )
nearestNode = None
dist = 999999999.0
for node in nodes:
d = ( node.position ( ) + ( node.size ( ) * 0.5 ) ).distanceTo ( pos )
#print “{0} {1} {2}”.format(d, node.position(), node.name())
if d < dist:
nearestNode = node
dist = d
handled = False
if nearestNode:
if currentContext == ‘Object’:
networkEditor.cd ( nearestNode.path ( ) )
if currentContext == ‘Sop’:
if nearestNode.isDisplayFlagSet ( ):
handled = True
else:
if currentContext != ‘Object’ and not handled:
Feedback is welcome as always
Edited by - 2015年4月30日 16:02:50
Very nice!!!
https://gumroad.com/alexeyvanzhula [gumroad.com]
Thanks mate
I think most of users will assign it to Network Pane Hotkey, so you can use kwargs instead of paneTabOfType.
Maybe it will be 0.0000000000000000001% faster
Thanks that's a good point Changed the code to reflect that.
Very Nice!!
Thanks It would be awesome if I could conditionally assign it to wacom pen. I never use the right click menu on the network editor outside the nodes. It would be nice if this could be configured so if you right click on the empty area of the network editor, it would invoke this hotkey.
Can we get this to work in modern versions?!
This is 2026 version from Houdini supercharged extension:
_EXCLUDE_DISPLAY = {"Driver", "Shop", "Vop"}
_EXCLUDE_RENDER  = {"Object", "Driver", "Dop", "Shop", "Chop", "Vop", "Lop", "Cop"}
def toggleNodeDisplayFlag(node, context):
    if context not in _EXCLUDE_DISPLAY and hasattr(node, "setDisplayFlag"):
            node.setDisplayFlag(not node.isDisplayFlagSet())
def toggleNodeRenderFlag(node, context):
    if context not in _EXCLUDE_RENDER and hasattr(node, "setRenderFlag"):
            node.setRenderFlag(not node.isRenderFlagSet())
def findNearestNode(editor):
    pos = editor.cursorPosition()
    currentPath = editor.pwd().path()
    nodes = hou.node(currentPath).children()
    nearestNode = None
    dist = 999999999.0
    for node in nodes:
        d = (node.position() + (node.size() * 0.5)).distanceTo(pos)
        if d < dist:
            nearestNode = node
            dist = d
    return nearestNode
def displayNearestNodeInEditor():
    editor = hou.ui.paneTabUnderCursor()
    editortype = editor.type()
    if editortype == hou.paneTabType.NetworkEditor:
        nearestNode = findNearestNode(editor)
        if nearestNode and editor.pwd().isEditable():
            with hou.undos.group("Display Nearest Node"):
                context = nearestNode.type().category().name()
                toggleNodeDisplayFlag(nearestNode, context)
                toggleNodeRenderFlag(nearestNode, context)
animatrix_
    nearestNode = None
    dist = 999999999.0
    for node in nodes:
        if d < dist:
            nearestNode = node
            dist = d
    return nearestNode
Very grateful, thank you! Although for some reason it still doesn't work. Nothing happens when I press the keys. I see you define some functions but if I'm not mistaken they're not called.
coccarolla
animatrix_
    nearestNode = None
    dist = 999999999.0
    for node in nodes:
        if d < dist:
            nearestNode = node
            dist = d
    return nearestNode
Oh yes I didnt include the call because that depends on how you want to use them. So you can just include a simple function call at the end of the code like this if you want to use them from shelf tool via a hotkey for example:
Not sure about posted versions, but this version works 100%, 99% of the time and is optimized 110%.
import hou
def node_supports_display(node):
    try:
        return True
    except:
        return False
def node_distance_to_cursor(node, pos):
    p = node.position()
    s = node.size()
    min_x, max_x = p[0], p[0] + s[0]
    min_y, max_y = p[1], p[1] + s[1]
    # Clamp cursor to node bounding box
    x = min(max(pos[0], min_x), max_x)
    y = min(max(pos[1], min_y), max_y)
    closest = hou.Vector2(x, y)
    return closest.distanceTo(pos)
def find_nearest_node(editor):
    nearest = None
    best_dist = float('inf')
    for node in editor.pwd().children():
        if not node_supports_display(node):
            continue
        d = node_distance_to_cursor(node, pos)
        if d < best_dist:
            best_dist = d
            nearest = node
    #print("cursor:", pos)
    #print("nearest:", nearest.path() if nearest else "None")
    return nearest
def sloppy_node_selection():
    if not editor or editor.type() != hou.paneTabType.NetworkEditor:
        return
    nearest = find_nearest_node(editor)
    if not nearest:
        return
    with hou.undos.group("Set Display Flag on Nearest Node"):
        nearest.setDisplayFlag(True)
        nearest.setRenderFlag(True)
Edited by hMonkey - 2026年3月9日 00:10:55
