1.Fedora 8 and houdini-9.1.179-linux_i686_gcc3.4.7z.Work OK.
2.When the license has expiried(monthly - Apprentice), I installed
Fedora 9 and houdini-9.5.156-linux_i686_gcc3.4.7z. System was
UNSTABLE. I have uninstalled them. The license has not expired
(monthly - Apprentice).
3.I've return Fedora 8, and downloaded
houdini-9.5.170-linux_i686_gcc3.4.7z. I can't unpack it. I have got
message: Error.
Thanks for the support in advanse !
acaiborka
Problem with unpacking: houdini-9.5.170-linux_i686_gcc3.4.7z
7404 3 1- acaiborka
- 31 posts
- catlee
- 139 posts
- chrism
- 2494 posts
- acaiborka
- 31 posts
Hi chrism and catlee,
Thanks for your support - I have installed and run HOUDINI but:
1.Color Settings -> Color Sheme:
a) Houdini Pro is bright (washed out),
b) WW_Dark HiCon: MENU=> Windows ->Desktop: Animate, Look_De
velopment, Model - Viev is bright (washed out); and … ->Desktop: Build, Output, Posing, Technical - Scene View is also
bright (washed out). The other panells in all desktops are OK.
2.When I run Help: -> Start Here (http://localhost:48626/start/) [localhost] or ->
Houdini Help (http://localhost:48626/) [localhost] or -> Example Files (http://localhost:48626/examples/) [localhost] I have got the message:
Server Error , like this =>
Module paste.evalexception.middleware:306 in respond …
>> app_iter = self.application(environ, detect_start_response)
Module houdinihelp.wsgi:399 in dispatcher …
>> return app(environ, start_response)
Module houdinihelp.wsgi:105 in wikiapp …
>> encoding = “utf-8”)
Module houdinihelp.streams:348 in renderpage …
Module houdinihelp.providers:504 in load …
TypeError:_init_() got an unexpected keyword argument `allow_exec`
Thanks for the support in advance !
acaiborka
>> encoding = “utf-8”)
acaiborka
