Few days ago I have upgraded my Ubuntu to 9.04 (I use *64 bit version).
Now I have problem with installation of Houdini 10.
At the first start of Houdini, appears a window with invitation to install aprentice license. But I can't press “next” Button - it not works
Any hjoudini window does not distinguish pressing of the mouse, buttons are not pressed.
it is the same on GNOME (with compiz turned off) and KDE
houdini + ubuntu 9.04
26524 23 3- wiTcHer
- 7 posts
- probbins
- 1145 posts
- wiTcHer
- 7 posts
- JColdrick
- 4140 posts
- Pagefan
- 519 posts
- AndersBP
- 12 posts
I am running Houdini on ubuntu 9.04(64 bit) recently and have no problems what so ever.
Your problem might be the screen driver. I had a similar problem with the licence server a while ago and it turned out to be a faulty screen driver that came with a OS upgrade( the repository drivers always seem to be acouple of versions behind)
Try downloading and install the latest screen driver for your system again
cheers
Anders
cheers
Anders
- haikalle
- 19 posts
I have a similar problem. With my ubuntu 9.04 when I open houdini the program dosen't respond at all. Window will show up on the screen but I can't click anything. Funny thing in this is when I open second houdini (“not closing the first houdini”) it works perfectly. I did installing using this method.
My specs are:
Quad 6600
Nvidia 8800 GS
My specs are:
Quad 6600
Nvidia 8800 GS
- MagnusL3D
- 1110 posts
If you'r problem is that you can't press the “next” button or interface with houdini with Ubuntu 9.04 and Nvidia cards try putting this:
Option “RenderAccel” “false”
in your Section “Device” part of xorg.conf
There seems to be a issue with the Nvidia drivers regarding this, and turning RenderAccel off helped me in the exact same situation.
Example:
Section “Device”
Identifier “Configured Video Device”
Driver “nvidia”
EndSection
/M
Example:
Section “Device”
Driver “nvidia”
EndSection
/M
- vmur
- 82 posts
Same problem here, Houdini don't respond to mouse clicks.
Option “RenderAccel” “False”, Option “AddARGBGLXVisuals” “False”, no compiz and others, don't work. Nvidia drivers update neither.
If you open another Houdini, this instance works like a charm.
But if you change to other virtual linux desk, the working houdini freezes again, but the original become to live.
It seems like a easy issue to fix for Houdini developers, I think so.
We are obliged to update Ubuntu 7.10, because It hasn't support/updates since April.
Just to inform, HDK with g++ 4.3.3 works.
Houdini 10.0.275 64bits
Ubuntu 9.04 64bits
Nvidia driver 180.53 64bits
Ubuntu 9.04 64bits
- haikalle
- 19 posts
- symek
- 1390 posts
- ragupasta
- 349 posts
- haikalle
- 19 posts
- vmur
- 82 posts
SYmekvmur
Ubuntu 9.04 64bits
Strangly, I have the same combination here on quadro fx 3600m, with no problems what so ever.
Thanks SYmek for the tip, I use a Quadro FX 3500.
But I have a wacom table too, I can't test it at this moment, I hope this is the problem. Thanks haikalle & ragupasta to public the wacom issue.
- Pagefan
- 519 posts
- harlequin
- 87 posts
I am having the same problem but mine is that I can't connect to the internet. I had a wacom tablet but unplugging it didn't help.
I am running ubuntu linux 9.04 and I installed aprentice. I started up houdini and it tried to connect to the license server but couldn't. I tried to do the workaround listed on http://www.sidefx.com/index.php?option=com_content&task=view&id=1283&Itemid=9 [sidefx.com] and http://www.sidefx.com/index.php?option=com_content&task=view&id=1283&Itemid=9 [sidefx.com] but I have a problem
I tried to open /usr/lib/sesi but I do not have a file sesi also, I don't have a file called sesinetd in path /etc/init.d
Is there a fix for this?
I am not sure I installed as root or not but I am going to uninstall and try and install it again as root.
- vmur
- 82 posts
The problem is the wacom, definitely. When you unplug it, houdini get the focus again.
Searching any solution now. I will write here, if I find something.
harlequin, you should open another entry in the forum with a nice subject for better support, your problem is different.
And remember, install as root.
- Pagefan
- 519 posts
In /opt/hfsxx.xx.xx there is a directory houdini/sbin
copy the contents to /usr/lib/sesi
copy the sesinetd.startup to /etc/rc.d/runlevel or /etc/init.d or /etc/rc3.d or whatever…
then add it to the runlevel scripts with whatever script your linux distro uses to add bootup scripts to runlevels (yast, rc-update etc)
of course you have to do this as user root.
Complain to the oss community and to Wacom about the lack of support for the tablet.
- vmur
- 82 posts
Odforce thread about this topic
http://forums.odforce.net/index.php?showtopic=9098&st=0&gopid=60046&#entry60046 [forums.odforce.net]
… no solution yet, but maybe it gives new ideas to somebody.
- derrick
- 329 posts
