gamma 2.2 workflow
13702 12 4-
- Andrew Graham
- 151 posts
i've discovered the colour settings in the edit menu to set a gamma 2.2 workflow. problem is i can't figure out where to set the gamma on imported images in my shader vops so they dont get corrected twice. any hints?
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
- circusmonkey
- 2624 posts
- Andrew Graham
- 151 posts
mad. that worked.
- debris
- 26 posts
- symek
- 1390 posts
debris
I hope the linear workflow in Houdini gets improved a lot soon
God! I hope not. Workflow is perfectly clean as it is. Preset color correction on any color/image viewer and a whole internals made linear unless user explicitly wishes to change it (via gamma correction in a shader for example).
The way how mantra proceed with *.rat files could be managed more friendly (the way I mentioned here as an example), but that's enough. Less guessing, less troubles.
- http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=18139 [sidefx.com]
- circusmonkey
- 2624 posts
- debris
- 26 posts
I “tried” Softimage XSI the last 9 years
The linear workflow as it is there is perfect. Especially in a Nuke / OpenEXR pipeline.
As I'm not (yet) a Houdini user on a daily basis: is there any script or easy workflow to avoid de-sRGB-ing literally _every_ texture that goes into it by hand? The only things that go in as they are would be HDRs / EXRs, as they're already linear.
Looks like I still have a lot to adopt…
Ceterum censeo Autodesk esse delendam!
- circusmonkey
- 2624 posts
You build your shader once whenever you use a texture in your shader it gets the auto de gamma. The work flow is very easy.
To be honest this stuff should be in the basic shaders that ship with Houdini. along with more real world production shaders as what ships currently is not up to par with what productions use.
rob
rob
Gone fishing
- debris
- 26 posts
circusmonkey
rob
Sounds reasonable. Now if I can get it to filter the incoming textures by e.g. filename extension and _don't_ de-gamma files which are already in linear space (e.g. EXR and HDR) this comes close to the workflow in XSI.
Thanks Rob!
- symek
- 1390 posts
debris
Thanks Rob!
The point is you don't want to render anything but *.rat files at all, and Houdini doesn't do it for you (Mantra does, but that's not an option). So linearizing is not a problem once you have to convert images to rats anyway. Workflow enhancement would be if Houdini starts treating *.rat as temp files, similar to prman or mental ray, and making auto conversions based on file's stat data. Ideally any texture call from within vex could trigger some action defined by a user.
For now keeping all *.rat files in sync with your source images, is tedious but easily script-able (and linearizing is just a small addition to a process)
- debris
- 26 posts
- edward
- 8113 posts
- JColdrick
- 4140 posts
