Cant cookie twice?
5804 8 0-
- yul000
- 9 posts
- 9432 posts
- yul000
- 9 posts
- rmagee
- 1344 posts
- オンライン
If you are creating a circular floor with a circular hole in it then I wouldn't use a boolean operation. I would create grid in the XY orientation, set the rows and columns to 2 and 2 then size it into a slab profile then offset it from the origin at the geometry level. Then I would then revolve the shape to get the circular slab with the circular hole in it. I have included an example file. Once you have the one floor then you can use a duplicate node to add the other floors…
Booleans seldom result in clean topology. If possible, I try to build a hole like this by hand.
- yul000
- 9 posts
- rmagee
- 1344 posts
- オンライン
Post a picture of the slab and I'll take a crack at it. As I said, I try to build these things up instead of using booleans if at all possible…
Oops - just saw the picture - it doesn't show up when not logged in. I will tinker and post a sample file. Actually can you post the scene file - it would be easier to do a test with your actual scene - Cookie might actually be the right solution given the model you are working with.
- rmagee
- 1344 posts
- オンライン
- 9432 posts
yul000
Thanks reversing works for the example.. But my real problem is this.. i reversed e normals but it does not cookie in a clean manner.
that's because your geometry is quite bad for this
your points are not fused, so it's just like many individual polygons touching at the edges
simple fuse SOP will not work because you have double faces in there too
if you display face numbers you can see it
so if you can correct your geometry before export or delete double faces manually (i can't think of procedural way right now) and then fuse them together with Fuse SOP
then it should work as the first example
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- 9432 posts
