I got around the initial error of houdini popping up then vanishing by running:
export HOUDINI_ENABLE_LINUX_THREADED_UI=0
Now onto problem number two. I get the “could not obtain GLX visual” error but I know my 3D acceleration is up and running fine. Everything else that uses openGL works fine. I get this when I run glxinfo:
name of display: :0.0
display: :0 screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
GLX_EXT_fbconfig_packed_float, GLX_EXT_texture_from_pixmap,
GLX_EXT_framebuffer_sRGB
GLX extensions:
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_SGIX_fbconfig,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 8500 GT/PCI/SSE2
OpenGL version string: 1.2 (2.1.1 NVIDIA 100.14.19)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multitexture,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow,
GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_window_pos, GL_ARB_texture_non_power_of_two, GL_ARB_vertex_program,
GL_ARB_fragment_program, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_EXT_texture3D, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_vertex_array,
GL_ATI_texture_mirror_once, GL_IBM_texture_mirrored_repeat,
GL_NV_blend_square, GL_NV_texgen_reflection, GL_NV_texture_rectangle,
GL_NV_texture_env_combine4, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x2c 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1868967532 1700946252 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 1919903278 1953720652 None
0x2e 32 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 1936280618 174483046 Ncon
0x2f 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 1853190002 1735091041 Ncon
Can anybody help - it's really irritating me now - I want to see what houdini can do.
