i have tried downloading and installing ALL 64bit linux clients. NONE work. i do not know if it is due to corrupt download or not, but i have tried downloading each one SEVERAL times in a row, deleting the old one before i do.
the archive manager or whatever it is called always gives an error when trying to open the package. i have also tried to manually extract the contents for a manual install, and it still wont work using tar -xvzf command in the terminal window. i just do not get what is wrong. i understand that this is not ubuntu 7.10, but still, it SHOULD work if it works for 7.10.
has anyone else ran into a similar issue?
problem with installing ubuntu 8.04 64bit...
7873 16 2- avirnig
- 2 posts
- Sean4000
- 4 posts
- Pagefan
- 519 posts
- Sean4000
- 4 posts
- rafal
- スタッフ
- 1450 posts
- mut8edseabass
- 5 posts
- Pagefan
- 519 posts
- varomix
- 460 posts
- Pagefan
- 519 posts
- WoundedKnee
- 1 posts
- varomix
- 460 posts
- Sean4000
- 4 posts
- Sean4000
- 4 posts
- Pagefan
- 519 posts
- avirnig
- 2 posts
i had the exact same error as sean. the windows versions work perfect for me, however ANY of the linux versions just will not extract. i have tried all the commands here, and NONE extract them. and yes, i did check the md5 sum each time. they matched each time, yet produced that same error unfailingly, EVERY TIME.
i just think it is some sort of issue with ubuntu 8.04.1 64 bit.
- Unaided
- 49 posts
I was downloaded all Debian versions, and when I download from linux browser (opera and firefox), the .tar.gz file is not valid gzip header.
$ file houdini-9.5.170-linux_x86_64_gcc4.1.tar.gz
houdini-9.5.170-linux_x86_64_gcc4.1.tar.gz: exported SGML document text
However when I download from Windows browser (firefox and opera also), the file header is a correct gzip header.
houdini-9.5.170-linux_x86_64_gcc4.1.tar.gz: gzip compressed data, from Unix, last modified: Fri Jul 18 07:42:55 2008
I was tried download Redhat and Linux packages versions, and .7z self-extracting file works ok. Extract and install, all ok. His header is correct.
file houdini-9.5.170-linux_i686_gcc3.4.7z
houdini-9.5.170-linux_i686_gcc3.4.7z: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), for GNU/Linux 2.6.9, dynamically linked (uses shared libs), for GNU/Linux 2.6.9, stripped
Anyone have a idea of why downloaded .tar.gz with linux is bad header??
Unaided
Unaided
- Unaided
- 49 posts
I think the possible problem is resolved now.
Today I download again .tar.gz package versions, both gcc3 and gcc4, and now the file header is ok.
$ file houdini-9.5.170-linux_x86_64_gcc3.4.tar.gz
houdini-9.5.170-linux_x86_64_gcc3.4.tar.gz: gzip compressed data, from Unix, last modified: Fri Jul 18 08:03:14 2008
