Hello all,
I have a global var called LOD ($LOD). In my pre-render script i tried
set LOD = 1 (also tried -g)
and
setenv LOD = 1
Sometimes this works, but most of the times it does not. If I make a simple copy sop and set the number of copies to 10*$LOD, typing above statements in a texport wont change the number of copies, until I force a re-cook of the node. Unfortunately, running it in the pre-render script does not always pick it up either.
Is there a better / more reliable way to do this?
Koen
ps. Houdini 9.5.303 on linux
Set / setenv in pre render script
3472 4 1- koen
- 789 posts
- jason_iversen
- 12468 posts
An alternate way is to use a ch() reference to a LOD channel, and use Takes to switch between LODs, perhaps?
- koen
- 789 posts
- mark
- スタッフ
- 2591 posts
koen
Hello all,
and
setenv LOD = 1
Koen
With environment variables, you might have to run the “varchange” command.
- koen
- 789 posts
