change ONLY PARTICLES color in viewport
   1972   2   1
Hi! Is there any method to change the color of particles in viewport, because when I've got solid geometry I want, that it's wire color would be dark and the particles color would be near to white.
In the config file : ‘3DSceneColors.wb’ there is only one variable :'WireframeColor: 0.80 0.80 0.73' - but this variable controls particles ANDgeometry color
Is there any method to set “separate” colors to both of these things?
Thank you
you could use a color sop?
Stephen Tucker
VFXTD
Yes that's true and for now that is the only solution, but can I change this in any setting file, that always the "default color of (for example) particles willbe (for example) red?
