In the houdini help there's a section on exporting simulation data to other networks.
You can pull out any type of geometry data from a simulation, including not just the final simulated geometry, but also collision fields, visualizations, and guide geometry. Look in the details view to see what data is available on a given object.
I tried looking in the details view to pull the pin contstraint lines from the Dynamics pendulum example into a geo via an object_merge. I can grab the simulated pendulums but not the lines that connect them.. which id like to do..
Hey Jeff, trying to extend this for a second constraint, and could use some input. if you check out the pendulum example there is a pin_upper_pendulum constraint for which this works great.. but then there is a pin_pendulums_together constraint which connects a secondary pendulum to the first for which this doesnt work so great. any input? mucho gracias!
oh and there are a bunch of chop nodes like null and rename that have an export prefix as /obj. Is this necessary or just a default? It generates a bunch of otl parameter warnings that a reference is being made outside of the hda. Ill try getting rid of it and see what happens.
yeah, all chop nodes appear to have a common tab with and export prefix set to /obj (by default). The operator type manager complains about all of these when trying to save the hda.. a bug perhaps?
Im poking around with adding a point for the GoalAnchor of the secondary constraint without much success.. the result is still evaluates to z=0 and y=0…
sdugaro yeah, all chop nodes appear to have a common tab with and export prefix set to /obj (by default). The operator type manager complains about all of these when trying to save the hda.. a bug perhaps?
it's not a bug. when rigging characters as HDAs I always delete the Export Prefix on the Common Tab…never had any problems.
goldfarb! how u doin brother? whats up @ c.o.r.e? go see cloudy with a chance of meatballs. I dont think an animated feature has ever made me laugh so hard since the first storyboards of the wild.
ok, since it doesnt look like theres an immediate way to get constraint geometry ive instead added 3 points (the origin, the centroid of the first pendulum, and the centroid of the 2nd pendulum) delete all points but the centroid, merge them together in the order i want and use another add sop after the merge to create the lines i need, with a final polywire to get some renderable geom for the constraints..
This HDA is wicked however… and with a little effort i think it can be tweaked to lookup and use the worldspacepos and offset of the CurrentAnchor and GoalAnchor from the Relationships folder of the Dop Network.
