Hello all,
In houdini 10 I made a shot otl that I would hook into the Geometry shader input of an output.
How would I connect this in houdini 11? My otl is available in the shop contect, but if I dive into a billowy smoke for example, my otl is not available.
What would be the best way to do this in 11?
Any help is appreciated,
Koen
Connecting Geometry/Procedural shops
3203 4 1- koen
- 789 posts
- rafal
- スタッフ
- 1449 posts
- koen
- 789 posts
Thanks, the problem I am running into however, is that I dont know how to convert the shop operator to a vop operator (or how to create a new vop otl, I dont mind redoing it.)
I had a hard time finding information in the help and most references to procedruals still mention to create a new operator type (shop). I tried to create a new vex geometry shader, but that did not show up either.
How would I go about converting the shop type to a vop type?
Thanks,
koen
ps. both in my local help and in the online help, the “shading Creating Materials” page is empty / broken.
Thanks,
koen
- derrick
- スタッフ
- 329 posts
koen
The simplest way to create a VOP for your geometry shader is to copy an existing one then modify it to match your shader. For example, you can open up the Operator Type Manager, right click on an existing Procedural VOP like the VEX Volume Procedural and choose “Copy…”. Give the operator the same name as your procedural then use the Type Properties dialog to change the Parameters, Help, and Input/Outputs.
- koen
- 789 posts
