Hello!
I`m start to render more and more this days with Houdini,
if some one can direct to easy and comfort way to Set up render passes in Houdini 11 it will be great.
I`m work on little project (with no passes)
http://www.sidefx.co.il/wp-content/uploads/2011/04/pp3.jpg [sidefx.co.il]
I`m sure its general question that many users looking for answer and example which not really exist(as far as i looked) in sidefx.com web site.
I added simple file to implement the example on it .
thanks !
j.
Setting up render passes Houdini 11
6934 3 2- James_Burg
- 153 posts
- uniqueloginname
- 330 posts
- grayOlorin
- 1799 posts
- arturmandas
- 33 posts
grayOlorin
Another way of approaching passes if you are working on a single hip file is to use Takes. One nice thing about Takes is that it allows for parameter overrides. If you are coming from Maya, extra image planes in mantra ROPs are like render passes, whereas Takes are like render layers
Thank you so much. This is the comparison I was looking for.
