# X is the gene number
# panel returns the number in the gene slider in GENOTYPE node
X = prim(“../each1”, 0, “primno”, 0);
panel = ch(“../../GENOTYPE/gene_`X`”);
return panel;
this code gives me an error in syntax in houdini.
the problem is with gene_X…is there a way to refer the value of X i get in the prev. line in the next line aling with a parameter name?? for example the value of X keeps changing from 1 to 500 and each time the it refers to the gene_X. I have attached the file
is there another way of writing this? Pls Help
help with HSCRIPT
1887 1 1- vigneshkaushik
- 20 posts
- tamte
- 8599 posts
