Is there a global variable to center the pivot on a UV transform sop which is is transforming a bunch of vertices in the UV editor .
Rob
UV transform centre pivot
5510 6 0- circusmonkey
- 2624 posts
- animatrix_
- 4528 posts
I don't think there is. I asked for an RFE for this exact same thing recently. CEX, CEY, CEZ is only for geometry.
- circusmonkey
- 2624 posts
- grayOlorin
- 1799 posts
is using a point sop to convert your UVs temporarily into 3d geometry an option (swizzling the TX, TY, TZ with MAPU, MAPV, and MAPW?) A lot of times I do this if I need access to geometry operations that may not be available for UV parameters. I think you may be able to use this to find the centroid of a group for the purposes of feeding it into a transformation
-G
- grayOlorin
- 1799 posts
- circusmonkey
- 2624 posts
- animatrix_
- 4528 posts
I didn't know they added that. Thanks Gray and SESI.
