moving line with a box
3165 2 0-
- dgslashn
- 6 posts
- オフライン
- tamte
- 9560 posts
- オフライン
create RBD and Wire objects through shelf (or manually)
press Attach Wire To Surface Shelf tool
follow status bar steps to complete
(in short they are
select wire, Enter
select points to attach, Enter
select rbd, Enter
select points on rbd (optional), Enter
it will be spring constraint by default so either tweak its stiffness or change it to Hard
(in short they are
select wire, Enter
select rbd, Enter
- goldfarb
- スタッフ
- 3465 posts
- オンライン
and there is this…
http://ihoudini.blogspot.ca/2011/10/wire-to-rbd-feedback-in-dops.html [ihoudini.blogspot.ca]
