make to object look at each other
6107 10 2-
- pelos
- 624 posts
- オフライン
- old_school
- スタッフ
- 2540 posts
- オンライン
Infinite recursion. All objects have transforms baked in. One can't orient to another and then back again. Just the way it is.
One way to get the proper transform is to take your two nulls, parent either another null, bone or any other object to each of the two nulls and then make the child object look at the other child's parent null and visa versa.
Now you can hang other nodes off of the objects with look-ats.
- old_school
- スタッフ
- 2540 posts
- オンライン
- pelos
- 624 posts
- オフライン
- old_school
- スタッフ
- 2540 posts
- オンライン
- jerry7
- 681 posts
- オンライン
- xukca
- 50 posts
- オフライン
Speaking about the Look At channel… what is the best way to do an aim constraint with excluding an axis (so it is two dimensional rotation, instead). I've tried with expressions and VOPSOP setups based on arcos cosine, and it works… except when one of the objects goes from Positive into Negative world spac. I would call it “cartesian jump”, because in VOPSOP the acos function expects an angle only between 0 and 90 (actually every positive angle should work despite limitations, but there is huge difference between 0 and 180 and -90 to +90). (I managed to reduce the jumps from 4 to 1 with some if expressions, but it is still very clumsy approach and it even doesnt support a full rotation, as the intention was…) :?
- old_school
- スタッフ
- 2540 posts
- オンライン
- xukca
- 50 posts
- オフライン
- old_school
- スタッフ
- 2540 posts
- オンライン
- xukca
- 50 posts
- オフライン
