Is it a bug?
5048 17 1-
- jerry7
- 681 posts
- オフライン
- anon_user_37409885
- 4189 posts
- オフライン
- jerry7
- 681 posts
- オフライン
- Sadjad Rabiee
- 1391 posts
- オフライン
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
Do you have a file that shows this? I imagine that you are getting more bounce and you only see the result per-frame, so it just looks larger.
Not sure if it will work but you can change the playback framerate in the playback options. Try setting it to 0.1 and see if you can see it animation slowed down.
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
- Nima
- 471 posts
- オフライン
- 4189 posts
- オフライン
- Nima
- 471 posts
- オフライン
MartybNzfinally i get houidini 13.0.376.
Hi Nima - the file displays fine in the latest production build Houdini 13.0.376.
It's probably best to use the latest version when encountering issues.
i stiil have these problem in last production build so i change open GL3.3 to GL2.1 and i took picture for bad fracture in houdini in same number of point in scatter node.
still it's not a bug?
i attach project before and i just change number of point in scatter node to 187 for appear this problem.
- 4189 posts
- オフライン
