nested foreach problem
2981 2 1- oat
- 479 posts
I'm trying to model the geometry as shown in the image below: each cell is composed of a cross-shape tower and 4 L-shape perimeter buildings.
It works for just one foreach node with a uniform height (the 1st hip file).
I want to have height variation across different cells by using nested foreach loop. i.e. each polygon within a grid (2x2 or higher) will be subdivided into four polygons, each will be used to construct one quarter of the cross-shape tower and one of the 4 L-shape building over the diagonal corner.
However, the geometry in one cell is completely missing in the final results, and there is strange result within the top level foreach node sometimes. see image below.
May I ask why the the nested foreach nodes don't work?
- animatrix_
- 4521 posts
You have to make sure the names of Stamp Name and Index Stamp Name are different between each nested ForEach nodes.
This problem comes up a lot and is very hard to spot if you haven't experienced it before.
- oat
- 479 posts
