point rotations in VOPS
2167 2 1- AndyW
- 336 posts
In the example I've posted I'm using points to translate a list of objects with VOPSOP, but I'm hitting a brick wall with scale and rotation and I know it has to do with my unfamiliarity with the transform matrix VEX node. I'm adding random values per-point with an attribute create, any help is much apreesh
- animatrix_
- 4520 posts
The VOP you need is Make Transform. Though it would be much easier to just use the Make Instance Transform VOP and then copy your boxes onto the points using the Copy SOP.
- AndyW
- 336 posts
