Error: Couldn't remove old operator
   4804   3   2
Upon opening Houdini 14, I get this message:
And indeed cannot get the handles show up.
Did I make a mess myself and how to fix it?
Thanks, Robert
EDIT: I also noticed that some of the other SOP's stopped working properly. :shock:
Houdini, Cinema4D, 3Dcoat, Marvelous Designer
Ok, I solved it by deleting the whole Houdini folder in User/Documents
Don't know why and how this happened, if someone is willing to shed some light on it, I would be even more happy.
Thanks, Robert
スタッフ
This was likely caused by attempting to overwrite a factory node type, in this case the Add SOP, with a digital asset definition of the same name. To avoid such problems in the future, you'll want to put your digital assets into a custom namespace.
For future googlers. An answer that most likely solves the issue by LaidlawFX: https://www.sidefx.com/forum/topic/37800/#post-230305 [www.sidefx.com]
In short, if you have OPcustom.hda, delete it.
Edited by AnimGraphLab - 2023年5月29日 01:17:00
Generalist.
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
