I'm using the houdini autorig to rig the space suit in this work-in-progress render:
https://s3-us-west-1.amazonaws.com/distant-galaxy.com/maelstrom2/CliffInSuitOnFreightCapsule/M2.CliffInSuitOnCap.Jun21.E.HD.jpg [s3-us-west-1.amazonaws.com]
The autorig is working overall, but I have a question about blending weights at the joints. e.g. the calf bone should be capturing all the shin geometry as a rigid piece, the toe bone should be capturing the boot as a rigid piece. Which they are. However, I want the ankle bone to capture the flexible rubber bellows geometry at the ankle, such that it compresses and expands as the ankle rotates.
How do I blend the weights between the calf, ankle, and toe bone such that I achieve the desired blending in the suit ankle geometry?
Any advice would be much appreciated.
thanks
Autorig joint weight blending question
1899 8 1- syntheticperson
- 159 posts
- goldfarb
- スタッフ
- 3456 posts
- syntheticperson
- 159 posts
Thanks. Please find attached the lower leg. i.e. calf, ankle and boot, from the space suit. The calf and the boot are meant to be a rigid material. Only the ribbed geometry for the angle is meant to expand and collapse, like a bellows, to allow the boot to be rotated at the ankle.
I'd like to know how to paint and blend the weights to achieve the above.
thanks
thanks
- goldfarb
- スタッフ
- 3456 posts
- syntheticperson
- 159 posts
- syntheticperson
- 159 posts
- goldfarb
- スタッフ
- 3456 posts
ok…
in the attached file you'll find the workflow that I'd use on something like this…it only took about 20 mins…
I've captured the geometry to a simple two bone chain and then in SOPs I made some point groups the have more control on how the weights were distributed..and some other little tricks
I've added sticky notes but if you have any questions just ask.
- syntheticperson
- 159 posts
Hi Michael,
this is invaluable for me to study, as it gives me a better understanding of the rigging process.
In the mean time I also watched some more of this tutorial:
https://cmivfx.com/store/533-houdini+rigging+animation+fundamentals [cmivfx.com]
Which made me realise I had my mouse button functions set incorrectly.
I know now how to smooth weights, using the autorig workflow.
Much thanks!
Much thanks!
- goldfarb
- スタッフ
- 3456 posts
