Having a headache with this expression.
This works, padzero((2,($F-1)/$FPS))
this doesn't, padzero((2,($F-1)/$FPS)):padzero((2,$F%$FPS))
If I use the ticks ` which is in the tutorial, the first section won't work either.
Can anyone explain what is going on?
Is H15 now different to H12 and H13 when it comes to expressions?
Thanks :?
Learning Expressions intro lesson 5
2642 4 1- Ralph Pinel
- 112 posts
- Enivob
- 2551 posts
Are you trying to put a colon symbol between two zero padded values?
If so, the second padzero has a syntax error. Look at your parenthesis. padzero requires two values. Your comma is on the inside of the parenthesis when it should be on the outside. The parenthesis surrounding $F-1 are only needed to insure that the subtraction from $F occurs before division by $FPS. In the second padzero there is only one operation, modulus, so no second set of parenthesis are needed.
Here would be my guess.
`padzero(2,($F-1)/$FPS)`:`padzero(2,$F%$FPS)`
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Ralph Pinel
- 112 posts
- sidenimjay
- 702 posts
- Ralph Pinel
- 112 posts
