I'm trying to get my bend SOP to only be affected on points with red in the color channel, but I'm failing badly.
Any attribute I create is ignored by the bend SOP.
Any idea why?
Bend by color attribute?
3602 3 2- Werner Ziemerink
- 1265 posts
- MrReedSmith
- 49 posts
- Werner Ziemerink
- 1265 posts
- animatrix_
- 4541 posts
My Bend SOP/VOP also does this automatically given a scalar weight attribute:
http://orbolt.com/asset/animatrix::bend::2.00 [orbolt.com]
You have to do it internally inside the deformer as this is controlling the angle, so you can't just use lerp (linear interpolation) between 2 geometry nodes, which is why all Houdini deformers should have a weight attribute that can control the amount of the entire deformation.
