setting up parametric groups
5027 11 1-
- gswartz
- 24 posts
- オフライン
I have a grid set up as a cloth object. I want to constrain the points on each side to a box to hold it in place. So for example in this case it's a 30x30 grid meaning that the points on the right side go from 0,30,60,90… and on the left are 29,59,89,119,… I was hoping to feed the grid into a group node and set up some type of expression to create the group but am having trouble with it. Here's where I'm at for the first group which should give me 0,30,60,90…
0-(`chs(“../grid1/rows”)`*`chs(“../grid1/cols”)`):`chs(“../grid1/rows”)`
I get the following error:
Bad pattern specified 0-(30*30):30.
Possible problems: Number out of range or a syntax error.
Valid Syntax: start
examples: !1-10:2,3 1-10:2 * 0-5 1
So under the bad pattern specified message it is getting the count correctly from the rows and cols but not doing the multiplication to give me the result. Is my syntax incorrect or is this not possible to do? Thanks.
Valid Syntax: start
- gswartz
- 24 posts
- オフライン
I'm also wondering if this might be better to do in an attribute wrangle node with vex… but I'm pretty new to Houdini so I'm not quite sure where to start if that were the better way to do this. Ideally I'd like to expose this group from the grid node as a parameter that I can feed into the autodop network to the cloth constraint nodes.
- vusta
- 555 posts
- オフライン
- gswartz
- 24 posts
- オフライン
vusta
so you just want the borders of some geometry right ? (just use Group, untick Base group, enable Include by edges,tick unshared edges, change group type to points, might as well rename Group Name to borders for ease of reading)
Actually I don't want all edges. I want a group for the right side only edges and another group for the left side edges.
- tamte
- 9464 posts
- オフライン
- vusta
- 555 posts
- オフライン
- gswartz
- 24 posts
- オフライン
- vusta
- 555 posts
- オフライン
your End is set to 900, this is the cause why it didn't work (tho you could reasonable still expected it to work) anyway, leave it at 0 which I think is equivalent to ‘unlimited’.
I've set up the Group By Range to do both left/right sides in one go…I've also referenced the Columns (from the Grid) so that you can change the Grid resolution and it will auto update.
If you want to see the effect one by one, then tick/untick the appropriate ‘tick’, by default, it's showing the result of the bottom one (left side selection)
- gswartz
- 24 posts
- オフライン
vusta
Thank you!
- gswartz
- 24 posts
- オフライン
So I am trying to set up these groups as the constrained points. I thought I had the right expression in the cloth attach constraints but I'm getting this warning and error. Any idea what's wrong with my expression or setup?
constraint1:
Warning: cloth - /obj/AutoDopNetwork/clothattachconstraint1/constraint1: Constraint could not be processed by solver.
constraint1:
- vusta
- 555 posts
- オフライン
In your cloth flag, I've wired the l/r groups as part of the chain instead of leaving it off to the side. Then in autodop, you simply type in the group names that you've defined instead of the full path (you could manually define these too, try simply type in say 0-9 press Enter and you'll see red spheres, constraints, created at those points)
- gswartz
- 24 posts
- オフライン
vusta
Ah yes, ok that makes sense. Thank you for your help!
