In 3ds max when ever I select a vertex, edge, or poly, there was the X, Y and Z position at the bottom of the screen, which would tell me the position, and then I could move/set it.
I'm looking everywhere for it but don't see it anywhere. I use it so often, especially when making plastic parts so I can align things perfectly, but things like this seems to be way more complicated then they need to be, correct me if I'm wrong.
And I do thing Houdini is f-ing awesome, IMO max is starting to become out dated (a lot of the tools can mess your mesh up, or need manual fixing after), but max certainly made tools that you(I) use a lot, much easier and quicker to use, where in Houdini if you want to do the same thing, it seems to be a process.
World Position of _____?
2003 4 1-
- LittleRain
- 4 posts
- オフライン
- sepu
- 474 posts
- オフライン
- LittleRain
- 4 posts
- オフライン
- goldfarb
- スタッフ
- 3465 posts
- オンライン
- LittleRain
- 4 posts
- オフライン
