Hi there,
I have a problem exporting an .abc into C4D.
I always did the same workflow: Simulation/ROP alembic output driver(bgeo)/File (load the .bgeo)/ROP Alembic export/Open in C4D/work like a charm.
But recently i've changed my computer and for the first time I tried to do and animation and make an alembic, doesn't work
I tried a lot of things and I'm desperate right now, but I think somehow when I export .abc don't concatenate all the files and when I open it on Cinema, it only read the first frame. You guys know what I mean?
Is not a problem of Cinema (I open and old .abc file already and works great)
I use :
Houdini Indie
16.5.473
Cinema 4D R19
I share the file with you guys, thank you in advance.
Appreciated the help.
Alembic export
1463 2 2- helloiamramon
- 2 posts
- neil_math_comp
- 1743 posts
Could you try installing Houdini 16.0, (you can download it from https://www.sidefx.com/download/daily-builds/ [www.sidefx.com] ), and seeing if it has the same issue? You won't need to uninstall Houdini 16.5.
Edited by neil_math_comp - 2018年5月28日 09:24:11
- helloiamramon
- 2 posts
