Trouble with a boolean operation
1473 3 0- Aten
- 42 posts
Hi all, I'm only a week into learning Houdini and even though the curve is steep I'm finding it very interesting along the way. So apologies for any questions that may be a bit obvious. Currently I'm using a boolean to cut out windows from a building (yeah yeah my first building generator )
However it seems a bit hit and miss when the windows get cut out properly. The input mesh is watertight and the boolean meshes are just a bunch of scaled cubes (which also seem solid) If I set detriangulate off then everything works fine, but I kind of need the quads as the next step is to slice the building up in specific spots and i don't want all the extra points it introduces. See the attached images.
cheers - Aten
cheers - Aten
- Aten
- 42 posts
- Aten
- 42 posts
- Aten
- 42 posts
