I'm using Houdini 17.5.173 and creating a simple comp with an exr file and the fog node based on the z channel and a bg mask. For some reason when I render, I see seemingly random frames with buckets that don't have the fog applied. So it will be 1 or several squares on the rendered output images that don't have the fog in them.
Any ideas?
Thanks,
Adnan
Comp Fog not Rendering all Buckets with Fog
1223 2 1- madguru
- 96 posts
- Kate Xagoraris
- 46 posts
- madguru
- 96 posts
Thanks for the reply Kate.
It does not appear to me that it is clipping on a particular plane. It is more like some render buckets are not rendering the fog on each frame and it is not consistent. So I get several squares (I'm assuming render buckets) where the image is there, except for the fog, but the buckets around it have the fog.
Adnan
Adnan
