Automatically add favorites in Open /save file dialog
   2919   5   1
Hello!
In the selectFile function, I would like to add some favorite directories.
It is possible to add it manually with the + button (Add selected to Favourites).
Is it possible to add it automatically with some environment variables? or other?
I hope I am clear enough
François
Yes, create a ‘jump.pref’ file in your home houdini folder containing a list of paths or env vars that are paths.
for example:
$HH/vex/include
$HOME/projects
/opt/data/textures
jsmack
So I found this file in mydocs\Houdini17.5.
Could I put it somewhere in a custom path?
Is there any other way?
I think prefs can be elsewhere in the houdini_path, but I think they have to be suffixed with .nosave to be used. I've not tried to put the jump list anywhere but my own prefs folder, as it's a personal preference.
jsmack
Thanks! I will try that and tell you the result
Francois Devic
jsmack
If you can start Houdini with a custom package, it will have its own houdiniX.Y/ root folder. Putting the jump.pref there works as well.
