HQueue overhead [H18]
   1519   3   0
With an installation of Houdini Indie running under HQueue, what is the expected overhead?
A 3 machine setup is leaving a lot of performance on the table. i.e. a local render takes of grid takes 5 secs, via HQueue using the same machine, takes 80 sec.
Mixed environment, Mac / Linux
I have the same issue. HQ was blocked and idle for a very long time before working.
That's pretty standard, expect between 1 and 5 minutes of overhead per task on any renderfarm solution.
jsmack
It is not the case for older version pre H18.
EDIT:
This problem is solved by changing server's name to IP address.
Edited by jerry7 - 2020年7月10日 22:56:57
