Hello there,
May I know how to randomly set the colour to only red green and blue with no in-between?
thank you!
Set Absolute color
1473 2 0- Justinngjw
- 8 posts
- Enivob
- 2537 posts
Sure, you can use a fit function inside an attributeWrangle, and force the result into an integer.
Make sure to run over Primitives, not points, assuming you have packed primitives.
int color_index = int(fit01(rand(@primnum),0,3)); if (color_index == 0){v@Cd = set(1,0,0);} if (color_index == 1){v@Cd = set(0,1,0);} if (color_index == 2){v@Cd = set(0,0,1);}
Edited by Enivob - 2020年11月9日 11:55:24
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Justinngjw
- 8 posts
Enivob
Make sure to run over Primitives, not points, assuming you have packed primitives.int color_index = int(fit01(rand(@primnum),0,3)); if (color_index == 0){v@Cd = set(1,0,0);} if (color_index == 1){v@Cd = set(0,1,0);} if (color_index == 2){v@Cd = set(0,0,1);}
Thank you very much, thats really helpful! Just to let you know I wanted each geo to have its own colour, not each primitive, so I changed your code to @class instead of @primnum after I added a connectivity node before the wrangle. Again thanks man
