Access exposed "basegroup" parameter on Digital Asset?
   1483   3   0
I get an error when I have a group node inside my OTL and I expose the "basegroup" parameter and try to select points on the OTL controls, I want to be able to select points for a group.
File "Parameter Scripted Action", line 4, in <module>
AttributeError: 'NoneType' object has no attribute 'eval'
Can anyone fill me in how to get this working?
Vincent Griffith
Edited by VGriffith - 2023年4月21日 21:59:26
I would also like to know the answer to this...
Anyone? Staff?
it's because you are promoting only "basegroup" parameter but still using it's Action Button script on promoted parameter:
import soputils
kwargs['geometrytype'] = kwargs['node'].parmTuple('grouptype')
kwargs['inputindex'] = 0
kwargs['ordered'] = kwargs['node'].parm('ordered').eval()
soputils.selectGroupParm(kwargs)
which as you see tries to find on 'grouptype' and 'ordered' parameter and can't so it errors out
so you can either promote those parameter also, if you want to have choice
or just alter the Action Button script and hardcode the ones you didn't promote to specific value:
import soputils
kwargs['geometrytype'] = hou.geometryType.Primitives # or hou.geometryType.Points etc...
kwargs['ordered'] = False # or True
Edited by tamte - 2023年5月10日 17:55:59
Thank you Tomas!
