I'm using redshift to render a sequence on solaris. Bud crach with optix denoiser enabled.
redshift version is 3.5.17 and OS is RHEL9.
if you know the cause, please let me know. Below is the error message.
Denoising the beauty and 5 material AOVs final frames using OptiX/OIDN
78389: Fatal error: Segmentation fault (sent by pid 8)
-- TRACEBACK BEGIN --
Traceback from karma 19.5.640 (Compiled on linux-x86_64-gcc9.3):
stackTrace(UTsignalHandlerArg) <libHoudiniUT.so>
signalCallback(UTsignalHandlerArg) <libHoudiniUT.so>
UT_Signal::UT_ComboSignalHandler::operator()(int, siginfo_t*, void*) const <libHoudiniUT.so>
UT_Signal::processSignal(int, siginfo_t*, void*) <libHoudiniUT.so>
pxrInternal_v0_22__pxrReserved__::RS_renderContextClass::applyDenoisedBuffer(RSVector4*, RSBlockSink*) <RSHydra.so>
pxrInternal_v0_22__pxrReserved__::RS_renderContextClass::handleFrameCompletion_DenoiseAware() <RSHydra.so>
pxrInternal_v0_22__pxrReserved__::HdRedshiftRenderPass::_Execute(std::shared_ptr<pxrInternal_v0_22__pxrReserved__::HdRenderPassState> const&, std::vector<pxrInternal_v0_22__pxrReserved__::TfToken, std::allocator<pxrInternal_v0_22__pxrReserved__::TfToken> > const&) <RSHydra.so>
![](/static/djangobb_forum/img/smilies/sad.png)
pxrInternal_v0_22__pxrReserved__::HdEngine::Execute(pxrInternal_v0_22__pxrReserved__::HdRenderIndex*, std::vector<std::shared_ptr<pxrInternal_v0_22__pxrReserved__::HdTask>, std::allocator<std::shared_ptr<pxrInternal_v0_22__pxrReserved__::HdTask> > >*) <libpxr_hd.so>
pxrInternal_v0_22__pxrReserved__::XUSD_HuskEngine::doRender() <libHoudiniUSD.so>
pxrInternal_v0_22__pxrReserved__::XUSD_HuskEngine::Render(double) <libHoudiniUSD.so>
std::runtime_error::what() const <husk>
__libc_start_call_main <libc.so.6>
__libc_start_main_alias_2 <libc.so.6>
-- TRACEBACK END --
