I'll prefix this by saying I'm quite new to Houdini so please bear with me.
I am trying to make a mosaic generator from a texture. So far I have it that I can import a texture (attributefrommap), scatter points based on Cd, fracture with voronoi, exploded it a bit, and extrude then bevel top faces. All well and good. But ideally, the pieces arent just the same sizes, but based on the difference in hue/rgb. So if I have a large black dot ontop of a rainbow, the rainbow will be made of small pieces because there is a change in hue, whereas the black dot will be 1 piece (or multiple large pieces so its not just 1 large round piece).
So my thinking is I need to make a "density map" that I can use to drive the density attribute in my scatter node. The problem is I can't figure out how to create said map based on changes in rgb. And I would of course need control of the range, because not every black pixel will be exactly the same, so it would need to check for a range, and if the neighbouring pixel is outside that range, it would create a new scatter point.
Hopefully this makes sense.
Attached is my work file with the image removed from the attribfrommap node. I also added an image of an elephant that has some hue changes, but also areas of solid (or almost solid) colors.
Map by difference in hue/rgb
984 4 1- Sepins
- 2 posts
- jsmack
- 7808 posts
- animatrix_
- 4530 posts
Here is one way:
Store hue for each point first (Point Wrangle):
Here is one way:
vector hsv = rgbtohsv ( @Cd ); @hue = hsv.x;
float threshold = ch("threshold"); int pts [ ] = pcfind ( 0, "P", @P, ch("radius"), chi("maxpts") ); removevalue ( pts, @ptnum ); foreach ( int pt; pts ) { float hue = point ( 0, "hue", pt ); if ( abs ( hue - @hue ) < threshold && @ptnum > pt ) { removepoint ( 0, @ptnum ); break; } }
- Konstantin Magnus
- 670 posts
Hi Sepins,
you can transform to various color spaces:
and extract image contours after blurring val:
int mode = chi('mode'); int comp = chi('component'); string space[] = array( "cspace:rgb", "cspace:hsl", "cspace:hsv", "cspace:XYZ", "cspace:Lab", "cspace:tmi" ); vector clr = ctransform(space[mode], v@Cd); f@val = clr[comp];
f@density = abs(f@val - f@opinput1_val);
- Sepins
- 2 posts
