HDA not showing up in matlib
   1825   4   0
Hello, I'm having a problem where I need to copy over my hda from another project every time because it is not showing up in the tab menu.
The hda is supposed to be used in material libraries. But it doesn't show up in its tab menu.
vop_nanghe.dev.blank.1.0.hdalc (7.0 KB)
オンライン
NicTanghe
most likely because it doesn't match the default Tab Menu Mask defined on Material Library node
Incase future people land here the tab menu mask is simply in the properties window and you can change it to just be *
or if you want to be more specific you can ad a part of the name of the hda file.
Edited by NicTanghe - 2024年1月10日 08:06:30
Hello.
Was this for sop or lops?
i have same issue, that i was not able to create HDA that would show directly under material library in Lops.
I believe it down to the Mask, but using * or leaving empty doenst work.
for future reference
its the Tab Menu parm on MaterialLibrary node, not the HDA we are creating
