Is Karma Pyro material fully compatible with Karma XPU
   1405   4   1
I could not get a confirmation to this question anywhere, do you guys still use Pyro XPU preview? Is it not necessary anymore?
https://vimeo.com/user2163076 [vimeo.com]
Is it?
スタッフ
Yes, Karma Pyro material is fully compatible with XPU. When you dive into any MaterialX-based volume shader and see "Karma Volume" as its terminal node, you can expect it to work with XPU.
Thanks for the feedback, so Karma XPU preview should not be used anymore right?
スタッフ
Preview shader will continue to work, but given its limited feature set I would recommend using the full pyro shader instead.
