Setting N outward maintaining orientation
   963   2   0
Hi, community! I recently added a node to my library that allows me to cover a zone with tiles. I'm making some modifications to it so that it can work on a three-dimensional figure (currently, the node only works on a plane axis).
The problem I'm facing is setting the N outward from the geometry while maintaining the orientation of the tiles. To orient the tiles, it uses a normalized vector with the neighboring points and I would like to use a combination of the N of the original subdivided cube with it.
Feel free to dive into the HIP file—maybe I haven’t explained it correctly, or there’s something I’m missing.
Hip.hipnc (285.8 KB)
You might want to also use v@up. @N alone can't fully tell Houdini how to rotate the tiles. You can see more info in the documentation:
https://www.sidefx.com/docs/houdini/copy/instanceattrs [www.sidefx.com]
You need to use up and N to get precise alignment like Olivier said:
