How do I generate license diagnostic information?
License Diagnostic information is useful for debugging licensing issues:
To generate using the License Administrator (hkey):
- Start the Houdini License Administrator (hkey)
- Under the View menu, select "Diagnostic Information"
- Save the file and attach it in an email addressed to support@sidefx.com
By default, the username and hostname of checked out licenses are now obfuscated in Hkey. This may be changed in the preferences dialog.
Uncheck the Scrub User Names box.You may also press the "Email License Diagnostic to Technical Support" button from the Server Information tab in the License Administrator. This will launch your email program with the diagnostic file.
Using sesictrl instead of hkey:
If you are unable to use the graphical License Administrator (hkey), you can use the non-graphical command sesictrl.
- Launch the Houdini environment or directly call sesictrl from the installation location
- sesictrl diagnostic > file
- for example: sesictrl diagnostic > /tmp/diagnostic.txt
- Locate the file you saved to (for example, diagnostic.txt) and attach in an email addressed to support@sidefx.com
To generate the license diagnostic using H21's License Administrator, please refer to this page.
